Phanteks release their Glacier G1080 GTX 1080 Water Block
Published: 21st July 2016 | Source: Phanteks |
Phanteks have released new their Glacier G1080 Water Block for the GTX 1080 for the price of $129.99. This block is designed to be used with Nvidia's Founders Edition GPU backplate and comes with three 1mm LED mounts for GPU block illumination.
This block is designed and manufactured by Phanteks themselves, with a nickel plated copper cold plate, an acrylic top and an elegant sandblaster top. Sadly at this time, we have not seen any Phanteks backplates for their Water cooled GPUs.
Instead of standard Silicon O-rings, which are commonly used by other manufacturers, Phanteks has decided to use military grade Viton o-rings which are designed to be more durable and are more resistant to heat.
Phanteks has also launched a large range of water cooling fittings that include compression fittings, extensions, and fittings for several diameters of hard tubing.
The Phanteks Glacier G1080 water block has an MSRPs of $129.99, €129,90, and £99.99, all of which include any relevant taxes.
You can join the discussion on Phanteks' Glacier G1080 GTX 1080 water block on the OC3D Forums.
Phanteks have released new their Glacier G1080 Water Block for the GTX 1080.https://t.co/1IKhQBZrwU pic.twitter.com/aKVgLevvVN
— OC3D (@OC3D) July 21, 2016
That's a lot of wires which will look ugly inside ones case unfortunately...
http://www.overclock3d.net/gfx/artic...051426587l.jpg Read more on Phantek's Glacier G1080 GTX 1080 water block. |
Phanteks have released their new Glacier
do i win something for spotting this ?Quote
shouldnt that be
Phanteks have released their new Glacier do i win something for spotting this ? |
http://home.bt.com/images/internet-c...1107145132.jpgQuote
