Phononic Solid-State CPU cooler gives massive performance in a small form factor
Phononic Silid-State CPU cooler givesmassive performance in a small form factor
Phononic, the company revolutionizing cooling and heating with SilverCore solid-state technology, introduces a new and innovative, high-performance solid-state CPU Cooler. The Phononic model HEX 1.0 is the first in a series of CPU coolers and is now available for pre-order via the company's Indiegogo campaign.
Unlike traditional heatsink/fan CPU coolers that continue to grow in size, the HEX 1.0 is built to meet today's high-performance computing needs in a much smaller form factor, which allows consumers to utilize enclosures ranging from mini-ITX to full size EATX towers. The Phononic CPU Cooler comes equipped with a dedicated control board that provides Variable Assist Cooling (VAC). Users can maximize thermal performance while minimizing the power and fan noise associated with increasing CPU load conditions. VAC combines a state-of-the-art Phononic heat pump with electronic control hardware and firmware that allows the CPU Cooler to respond to the changing load and ambient conditions.
Using highly reliable solid-state technology, the HEX 1.0 CPU Cooler meets or exceeds the thermal performance of closed-loop water coolers but without the concerns associated with water in the system.
"Our HEX 1.0 CPU Cooler packs more cooling performance for a given size than any other CPU cooler on the market," explained Ted Donnelly, director of Phononic's IT Cooling business. "With the addition of our Variable Assist Cooling (VAC), users can maximize the performance of their system, while at the same time managing the fan noise associated with higher load conditions."
The Phononic CPU Cooler technical specs include:
  • - Fan heatsink with integrated Phononic solid-state heat pump
  • - Integrated 80mm fan with fully enclosed blades
  • - Compatible with the latest high-performance Intel processors
  • - Tested to TDP levels greater than 175 W
  • - Dimensions: 4.3" x 3.5" x 3.5" (H x W x D)
"At the heart of every computer is a CPU whose performance is dictated by the chip design, the clock speed and processor cache. As users push the limits of their high-performance systems, they create thermal loads that require a reliable CPU cooling solution to deliver the necessary performance," said Michael Bruno, vice president and general manager of Phononic's Electronics Cooling business. "With the innovative use of our proprietary SilverCore solid-state technology, we're disrupting the high-performance CPU cooling market by offering a solution that will not only meet performance needs but provide an option for safer, smaller, more durable processor cooling."
The Phononic CPU Cooler is available for pre-order from Indiegogo with special perks for early adopters, including an opportunity to participate as an extension of the Phononic engineering development team, a chance to win a trip to Phononic's headquarters to participate in the final product launch, discounted prices and more. Check out all pre-order options on this page.
The Phononic CPU Cooler will be available for delivery in November 2015.
You can join the discussion on Phononic's Solid State CPU cooler on the OC3D Forums
Meet the Phononic HEX 1.0, the world's first Solid State CPU Cooler which promises to beat coolers like the NH-D15 with only a single 80mm fan.
Posted by OC3D on Monday, 24 August 2015
«Prev 1 Next»
24-08-2015, 04:28:02
Tolemac
That would go nice in an "all silent" mini ITX build Quote
24-08-2015, 04:34:12
WYP
it is a very interesting Idea to use a Peltier in a CPU cooler, but this isn't the first time I have seen this.
Hopefully this project goes well.Quote
24-08-2015, 04:45:37
Agost
Soooo a peltier on a heatsink
I'm guessing it will be kinda expensive and not very efficientQuote
24-08-2015, 04:45:56
Kushiro
Haha, this would look adorable cooling my x99 rigs.Quote
24-08-2015, 04:57:40
MiNo
I'd love to see this work.
However, i fear they will still struggle with the low efficiency of peltier elements causing at least a rather high overall power usage. Meaning the CPU might be cool, but the room not. It will likely be more warm than any other type of cooling.
Also, why are there no pictures of the unit to be placed in a PCIe slot? The size would likely be important to many.
I wonder if anyone has ever made a setup with a AC unit in front of case intake fans. Lowering the intake air seems to me as something that would benefit all components - especially if both CPU and GPU could be set to expel heat out of the case, instead of into it.
Even better : More efficient CPU's :-)Quote
