Raijintek announce their Asterion Plus and Classic cases
Raijintek has announced their Asterion Plus and Classic cases, which feature either dual hinged acrylic windows or  dual tempered glass windows, depending on your preference.
This chassis will be available in both silver and black variants, with both the Tempered Glass and Hinged acrylic versions coming with the same internal layout, which includes a PSU shroud and the ability to accommodate EATX motherboards.
This chassis is designed for high-end water cooling setups, with support for a 360mm or 280mm radiator on the front and top of the chassis, allowing PC builders to cool even high end Multi-GPU setups with ease. This chassis also contains support for up to four 3.5" drives and three 2.5" drives and has space for a slot loaded DVD drive at the front of the chassis.
   Raijintek announce their Asterion Plus and Classic cases  Raijintek announce their Asterion Plus and Classic cases
This case will cost £152.99 for the Asterion Classic Tempered Glass versions and £159.99 for the Asterion Plus chassis which comes with hinged acrylic windows. For both versions of the chassis, windows will be on both side panels, which means that users will have to be very careful with their cable management, as it all will be visible.
Both of these cases are currently available to pre-order at Overclockers UK.
You can join the discussion on Raijintek's Asterion Plus  and Classic cases on the OC3D Forums.
«Prev 1 Next»
27-10-2016, 19:06:51
Thelosouvlakia
Front looks like the metis just a lot bigger, the top though reminds me of my Phanteks case o.O
Other than that I'm curious how good this will stack up to the competitionQuote
27-10-2016, 20:57:03
The3DLink
Really like this design. Clean and simple, and great watercooling support. Also, really like the slot load drive option. Only thing, wish the back side wasn't glass/acrylic. No matter how well your management is, who really wants to see their all their wiring?Quote
27-10-2016, 21:50:52
Dawelio
I can think of one person, his name is Snef, he's a PC builder and one of his builds, which is a inverted, mainly black build, with some blue accents to it... His cable management on that build was epic and spot on.Quote
27-10-2016, 23:23:32
m2geek
Looks like a InWin case...Quote
27-10-2016, 23:51:32
ImprovizoR
It looks like most of the cases on the market today.Quote
