Raijintek release Morpheus II Core Edition GPU Cooler
Published: 19th April 2016 | Source: Raijintek |
Raijintek has released their new Morpheus II Core Edition GPU cooler, offering up to 360 Watts of cooling capacity with dual 120mm fans.
This GPU cooler can be used passively with low TDP GPUs, but offers a large amount of cooling capacity when combined with two 120mm fans and most GPUs that are currently on the market. The previous iteration of this cooler has been highly popular for high-end air coolers for a long time, with this new version offering an improved design that offers a better mounting solution.
Below are the specifications of Raijintek's Morpheus II Core edition GPU Cooler, which supports most modern GPUs from AMD and Nvidia.
- - Cooling capacity up to 360 watts TDP
- - 12 pcs copper heat-pipes and 129 pcs fins for efficient heat dissipation
- - 24pcs heat-sink for RAM & 1 big heat-sink for VRM
- - High compatibility with modern & future VGA cards
- - Thermal adhesive to lower RAM and VRM temperature significantly and assure proper bond
- - Compatible with AMD R9 390x, R9 Fury, Hawaii chip (R9 290/290x), Curacao chip (HD 7850, 7870 xt; R9 270/270x)
- - Compatible with nVIDIA GTX Series Chip 970, 980, 980Ti, 780Ti, 780, 770, 760, 650, 650Ti, 660, 660Ti, 680
- - Supports two 120mm fans (8 fan clips in the box)
- - Whole heatsink black coated
You can join the discussion on the Raijintek Morpheus II Core Edition GPU cooler on the OC3D Forums.
