Raijintek releases their new Paean Tempered glass dual chambered chassis
Raijintek has released their new Paean Tempered glass dual chambered chassis, coming with a brushed-metal finish and support for up to a 360mm radiator.
This chassis will have a semi-open benchtable-like design, with the base plate being made out of 4mm thick Aluminium and two 5mm thick tempered glass side panels.
This chassis will support up to three 3.5"/2.5" drives and support full sized ATX motherboards and power supplies. At the front facing IO the case sports 4 USB 3.0 ports as well as audio in/out ports.
This case will support full-length GPUs that are up to 310mm long when a water cooling reservoir is installed and GPUs that are up to 400mm long without a reservoir installed.
    Raijintek releases their new Paean Tempered glass dual chambered chassis  Raijintek releases their new Paean Tempered glass dual chambered chassis
The Paean has no specific fan mounts but is completely open to your room's natural airflow, offering cooling performance that is similar to an open test bench.
At Overclockers UK the Raijintek Paean is now available for £149.99.
You can join the discussion on the Raijintek Paean Tempered Glass Aluminium chassis on the OC3D Forums.
«Prev 1 2 Next»
18-11-2016, 13:21:20
Wraith
So... it's a test bench with a glass lid stood on its side..Quote
18-11-2016, 14:18:04
SparkleDJackson
i think i just filled the cupQuote
18-11-2016, 14:32:05
Warchild
Id buy it over Corsairs offerings Quote
18-11-2016, 15:46:55
Wraith
Jay and Silent Bob, quote of the day!Quote
18-11-2016, 16:20:14
RickPlaysWarr
Anyone know if there is a place to buy this in the states. I like this much more than the Thermaltake Core P5 open air chassis I had been considering for a build.
--Rick--Quote
