Raijintek reveals their huge Morpheus 8069 360W GPU Cooler
Want to replace or upgrade your GPU's heatsink?
Need a new GPU cooler? Raijintek has a solution for RTX 30 series and RX 6000 series products
Raijintek has just revealed their Morpheus 8069 multi-compatible GPU cooler, a heatsink that is designed to be used with a variety of graphics cards to deliver improved cooling potential and 360 watts of heat dissipation capability. Why would you want to replace your GPU's heatsink? Maybe you want something beefier than your stock heatsink, maybe you have broken your GPU's stock heatsink, perhaps you are buying a formerly liquid cooled GPU without a heatsink. There are many reasons why you may want a new GPU cooler, and Raijintek's new Morpheus 8069 is designed to meet that need.
Raijintek has designed their new Morpheus 8069 heatsink to support a variety of RTX 30 series and RX 6000 series graphics cards, with Raijintek claiming compatibility with Radeon RX 6700, RX 6800, and RX 6900 series GPUs and GeForce RTX 3080 and RTX 3090 series graphics cards. This heatsink supports two 120mm fans, with the unit itself shipping without any pre-installed fans.
Press Release - Introducing RAIJINTEK MORPHEUS 8069
RJK THE SAGA GOES ON! The MORPHEUS 8069, completely black coated heatsink, a superior high-end VGA cooler, designed to meet cooling capacity up to 360 Watts of TDP. Morpheus 8069 comes with 12 copper heat-pipes, 129 fins, mirror copper base, and the option to install 2×120mm fans; the outstanding combination and design provide the best acceleration of heat dissipation process to assure your VGA board running under optimal temperature. Additionally, Morpheus comes with 5pcs copper & 4pcs aluminium heat-sink for cooling your PCB chips efficiently. Moreover, Morpheus 8069 is multi-compatible with most modern NVIDIA & AMD GPU’s.
Features
- Cooling capacity up to 360W TDP
- 12 pcs copper heatpipes and 129 pcs fins for efficient heat dissipation
- 5 pcs copper & 4 pcs aluminium heat-sink for cooling chips efficiently
- Thermal adhesive to lower RAM and VRAM temperature significantly and assure proper bond
- Compatible with AMD Radeon
- RX 6700/6800/6900/XT
- Compatible with NVIDIA GeForce
- RTX 3080/3090/Ti
- Supports two 120mm fans (8 fan clips; 4 cps for 12025, 4 cps for 12013)
- Whole heatsink black coated
You can join the discussion on Raijintek's new Morpheus 8069 GPU cooler on the OC3D Forums.
«Prev 1 Next»
02-11-2022, 11:38:34
Peace
Weird name, but 69 is always noice.
It's a solution alright, but is it a good one? Would be cool to see a test.Quote
02-11-2022, 21:33:44
Dawelio
At this point, just but the ASUS x Noctua edition instead, probably better built overall.Quote
