SilverStone Announces the Kublai KL05 Chassis
SilverStone Announces the Kublai KL05 Chassis - Press Release
SilverStone announced the Kublai KL05 series case. The Kublai KL05 is a high quality ATX tower case designed for enthusiasts with the need for ample liquid cooling and storage space. It has convenient tool-less 5.25" drive bays and highly flexible cages designed to accommodate any combination of 2.5" or 3.5" drives. With a relatively tall and slender profile, it has surprising room for fitting liquid coolers.
SilverStone Announces the Kublai KL05 Chassis  SilverStone Announces the Kublai KL05 Chassis
Not only does it have complete support for 240mm and 280mm radiators on both the top and the front panel, it has numerous paths for tubing, mounting holes for fans, and easily removable filters for an exceptionally cool and clean build. KL05 is offered in two variations depending on front panel design so whether the preference is for a direct intake case with side window or a conservative, quiet build with indirect intake and sound-absorbing foam, there is a model perfectly suited for the intended task.
Special Features:
  • - Interference-free design for mounting 240mm or 280mm radiator
  • - Highly flexible storage accommodation of up to 8 or 11 drives*
  • - Quick access filters for easy cleaning
  • - Motherboard back plate opening for quick CPU cooler assembly
  • - Mesh front panel intake maximizes airflow with side window for viewing system innards (KL05-W)
  • - Front-side intake vents with foam padded side panels to minimize noise (KL05-Q)
  • - All black painted interior for stylish look
The recommended End User price (excl. VAT): KL05B-Q/ KL05B-W: US $69.97.
The KL05B-Q/KL05B-W will be available in our stock on the 16th of June.
For more information, visit the product page.
My Thoughts
The one thing that this case screams is budget water cooling, the top and front support large radiators and the inside is fairly spacious, ideal for building a water cooling loop while remaining under the "budget case" classification.
We can see that to maintain the is case's low pricepoint Silverstone has had to cut some corners, taking away the rubber grommits that we would typically expect for a case of this price and size.
You can join the discussion on the Silverstone Kublai KL05 chassis on the OC3D Forums.
Silverstone has just announced their new Kublai KL05 Chassis.Is this the budge watercooler you have been looking...
Posted by OC3D on Thursday, 11 June 2015
«Prev 1 Next»
11-06-2015, 05:25:59
Feronix
Actually quite a nice chassis. Only thing that bothers me is that it's taller than it is long so it looks a bit silly, especially with the window and rather tall top panel.Quote
11-06-2015, 06:03:44
Dawelio
Looks fair enough, just not my cup of tea though.Quote
11-06-2015, 07:28:14
You_What?
Reminds me a bit of the newer FT series one, I like them. Quote
11-06-2015, 07:58:37
Greenback
was thinking more the Phanteks Enthoo luxeQuote
11-06-2015, 09:35:43
You_What?
Fair point, could possibly say its a mix of both?Quote
