SilverStone Raven RVX01 Mid-tower Chassis
Silverstone’s Raven series of cases has always been among my favourites, using a non-traditional, almost unique, top-oriented design that can’t help but display your hardware in a way in which many other cases simply cannot.
This new case is the Silversotne RVX01 and it will be releasing next month, but the guys over at TechPowerUp were given the opportunity to have a sneak peak at the design before this cases official announcement. As you can see it uses the same right angles design as it’s predecessors, offering enough space for large GPUs, PSU and almost any CPU cooler you can imagine.
SilverStone Raven RVX01 Mid-tower Chassis   SilverStone Raven RVX01 Mid-tower Chassis
This case is designed to come at a more affordable price than other Raven Series cases, coming in at around $80.
One change which many modern PC users will love is the lack of a external 5.25″ drive bay, suiting the many PC builders who no longer use optical bays. Inside there are 4 internal 3.5″/ 2.5″ drive bays, which gives users plenty of space for storage. The case of the case can hold 3x120mm fans and is suitable for a 360mm water cooling radiator, at the base there is also a large removable dist filter, which will help reduce the buildup of dust inside your PC.
At the front there is a single 120mm intabe and at the top there is a 120mm exhaust.
With a more modest price and a lot of space to work with Silverstone expects this case to be a great competitor in the case market. Let’s hope the EU/UK pricing of this case is not overly expensive.
You can join the discussion on Silverstone’s RVX01 Chassis on the OC3D Forums.
