Streacom Announces their new DB4 Chassis
Streacom has announced their new DB4 Fanless ITX Chassis, which uses its Aluminium exterior frame as a passive CPU heatsink.
All cables come out the bottom of the case, giving this monolithic chassis a clean, premium aesthetic. The case measures at 260 x 260 x 270mm, allowing it to accommodate any MITX motherboard and a dual slot GPU that is up to 200mm in length.
Below are the full specifications for the Streacom DB4 chassis, though the case will need to be upgraded with additional heat pipes in order to accommodate CPUs that have a TDP of over 65W.
The case also contains a universal CPU mounting mechanism, which allows this case to be compatible with most CPU sockets, provided that the motherboard is MITX.
Specifications
Chassis Material: Premium Grade (6063) All Aluminium, 4mm Thick Extruded Panels
Available Colours: Silver – Sandblast Finish
Motherboard Support: Mini-ITX
Drive Capacity: Maximum 5 x 3.5″ or 12 x 2.5″
Optical Drive Bays: Optical Kit for slim slot loading drive
Expansion Slot: 2 x Full Height Slots (MAX 200mm Length, 110mm Height)
USB Ports: 2 x USB3.0, Bottom Facing
Cooling: 4 x 6mm Heatpipes with 65W / Side Panel, Expandable to 120W
External Dimensions: 260 x 260 x 270mm (W x D x H)
Power Supply: ZF240 or Nano Series PSU (Not Included)
Remote Control: None
Net Weight: 7.5KG
          Streacom Announces their new DB4 Chassis  Streacom Announces their new DB4 Chassis
Right now the pricing and availability of the Streacom DB4 are unknown, but you can find out more on this new ITX case on Streacom's DB4 product page.
You can join the discussion on Streacom's DB4 Chassis on the OC3D Forums.
«Prev 1 Next»
