The Lian Li LANCOOL 4 is AMAZING!
Lian Li’s new LANCOOL 4 PC case is going to be legendary
We’ve had a look at Lian Li’s Computex 2025 booth, and we were amazed by what we found. Later this year, Lian Li will launch its LANCOOL 4 PC case, and we expect it to be one of the fastest-selling PC cases in the company’s history.
Just look at the front of this PC case. It’s made from a single tempered glass sheet bent on both sides and has three 140mm fans embedded into its surface. That’s right, Lian Li has created a glass-fronted PC case that can deliver high levels of airflow. That’s awesome.
The LANCOOL 4 has glass panels on all sides. There are some areas of the case where you can peer into one side and see out the other. When we first saw this case, I thought that it was going to cost an arm and a leg. No, this case costs $129.99, and it ships with three 140mm fans.
With an asking price of $129.99, we expect the Lian Li LANCOOL 4 to sell out as soon as it becomes available. This price is incredibly low for a case with this much tempered glass. Beyond that, its high airflow design will make it appealing to a larger audience than many glass-filled PC cases.
At the base of the LANCOOL 4, we have space for up to three 120mm fans. These fans act as intakes, drawing in air directly under your graphics card. That’s great news for users of hot graphics cards.
Honestly, Lian Li has done something amazing here. They have created a case with unique design elements and kept its MSRP affordable. We expect this case to sell out fast when it launches in October. It looks like a cracking case, and we see no reason why it would perform poorly in thermal tests. Well done Lian Li, this is a cracking good case.
You can join the discussion on Lian Li’s LANCOOL 4 PC case on the OC3D Forums.
