Thermal Grizzly expands its DeltaMate lineup with new fittings and colour options
Thermal Grizzly expands its DeltaMate lineup to give liquid cooling enthusiasts more options
Thermal Grizzly has expanded its DeltaMate lineup of custom liquid cooling hardware. Starting today, their DeltaMate fittings lineup will be available in “Matt Nickel”, giving PC builders more options. This allows PC builders to construct systems that match their aesthetic preferences. Now, these fittings are available in Black and Matt Nickel.
Alongside their new Matt Nickel options, Thermal Grizzly has also launched new FF90-degree rotary fittings and Extender FF14 fittings. These fittings give PC builders greater flexibility, enabling tight bends and tubing extensions. All DeltaMate fittings are precision machined from brass and are sealed with durable EPDM O-rings, ensuring reliable liquid cooling performance.
New Fittings: Matt Nickel for More Choice
With the matt nickel-plated fittings, Thermal Grizzly expands its product range and offers more options for building a custom water-cooling system. In addition to the new color variant, two new fittings are now available, each with two G1/4-inch female threads. The DeltaMate Rotary – FF90° and the DeltaMate Extender – FF14 are primarily intended for combining two fittings. For example, two short hard tubes can be combined into one long hard tube using two DeltaMate Fittings – HT16 and a DeltaMate Extender – FF14, or routed at a 90-degree angle using the DeltaMate Rotary – FF90° and two HT16 fittings, without the need to bend the tubes themselves.
– Thermal Grizzly
Below is an overview of the current DeltaMate water-cooling fittings range:
Fittings (water-cooling hose fittings):
  • DeltaMate Fitting – ST16 Black / Matt Nickel
  • DeltaMate Fitting – HT16 Black / Matt Nickel
Rotary Fittings (water-cooling rotary fittings):
  • DeltaMate Rotary – 90° Black / Matt Nickel
  • DeltaMate Rotary – FF90° Black / Matt Nickel
  • DeltaMate Rotary – T Black / Matt Nickel
Extenders (water-cooling extension fittings):
  • DeltaMate Extender – MF7 Black / Matt Nickel
  • DeltaMate Extender – MF10 Black / Matt Nickel
  • DeltaMate Extender – MF14 Black / Matt Nickel
  • DeltaMate Extender – FF14 Black / Matt Nickel
  • DeltaMate Extender – MF28 Black / Matt Nickel
Water Cooling Accessory Fittings:
  • DeltaMate Plug – Black / Matt Nickel
Thermal Grizzly’s DeltaMate fittings are available through Thermal Grizzly’s website and through partnered retailers.
You can join the discussion on Thermal Grizzly’s expanded DeltaMate fittings lineup on the OC3D Forums.
