Thermaltake launches the ultimate his/her dual PC case at CES 2026
Thermaltake’s View Cross TG is the ultimate PC case for streamers and his/her setups
At CES 2026, Thermaltake unveiled a concept PC case that wowed us. The View Cross TG, a new concept design from Thermaltake, is a PC case for dual PC setups. With this case, Thermaltake is targeting streamers and PC builders who want a single-case his/her PC hardware setup.
The idea is simple: a single, tall PC case that supports two MATX systems inside. For streamers, one system can be for gaming while another is for streaming. Alternatively, it can store two gaming systems and sit between two PC gaming setups. If you need two PCs in one case, the View Cross TG is the case for you.
(OC3D’s CES 2026 Thermaltake Booth Tour)
Thermaltake’s View Cross TG build houses two matching gaming PCs. All intake fans have blue LEDs, and all exhaust fans have red LEDs. The system has two sets of I/O at the top, and the case supports up to 13 120mm fans. Their setup includes two 360mm liquid-cooling solutions, one at the top and one at the side of the case. Note that up to two 280mm liquid coolers can be mounted on the side of this PC case.
Behind the case’s motherboard tray, there is space for up to four 3.5-inch drives, and up to six 2.5-inch drives. Thermaltake has confirmed that its View Cross TG design has not been finalised, and as such, we cannot unveil the case’s pricing or release date. Regardless, this is easily one of Thermaltake’s most exciting new products of CES 2026.
You can join the discussion on Thermaltake’s View Cross TG PC case on the OC3D Forums.
