Thermaltake Release The Cyclo Fan
News Posted 05/04/07
Author: PV5150
Source: Thermaltake
Official Press Release
Both 120mm and 80mm fans are engineered with low-noise bearing mechanism to minimize overall noise output at 17dBA and 19dBA, and the transparent shield cover not only protects user from being accidentally hurt by the fan blade but also extending reliable life span of the fan.
During operation, Cyclo Logo Series fan utilizes the build-in LED placed uniquely to display “Thermaltake” wording, current temperature and noise level at the same time. Complimented with blue LED in background to further enhances the overall aesthetic quality. Cyclo Pattern Series fans are available in Blue or Red. Both fans will display over ten playful patterns during operation utilizing the build-in LEDs.
With the release of Cyclo Series fans, computer enthusiasts and modders worldwide will be able to further enhance their unique PC.
A2449 – Cyclo 12cm Red Pattern fan
A2450 – Cyclo 12cm Blue Pattern fan
A2452 – Cyclo 8cm Red Pattern fan
A2453 – Cyclo 8cm Blue Pattern fan
A2460 – Cyclo 12cm Logo fan
A2461 – Cyclo 8cm Logo fan
