Thermaltake Unwraps External ProWater PW880i LCS Cooler
Cooling solutions manufacturer Thermaltake recently added an external cooling solution to its range of ProWater PC Coolers. According to the manufacturer, the ProWater PW880i LCS is a complete water cooling solution for the PC.Designed around a P500 pump, which has the capacity to circulate 8.3 litres of water a minute, the PW880i keeps the system performing at optimal levels through a constant supply of fresh, cool water. A 28cm radiator equipped with twin 12cm fans keeps the water cool, while placing speed and sound controls of the fans firmly in the hands of the user. Water supply comes for the semi-transparent reservoir, which can be topped up as required.
The waterblock is pure copper and fits most mainstream Intel and AMD CPUs. The external design of the PW880i allows easy installation and maintenance without disrupting the internal airflow of the system. The easy mount bracket allows the entire system to be attached to the rear fan mount. Additional accessories are also available for the PW880i for users who require more cooling power.
These include a VGA waterblock for high-end GPUs such as the Radeon HD 4890, a North Bridge block, and the M connector that allows users to split the cooling among parallel blocks. The M connector makes sure the water reaching each block is the coldest possible, making it far superior to serial block installations.
There is no word so far from Thermaltake on pricing or availability. Pictures of the ProWater PW880i LCS though show it to be a mean looking setup with tons of cooling ability, and one to look forward to.
Discuss in our Forums
