TRYX enters the CPU heatsink market with their LCD-clad TURRIS cooler
TRYX unveils its TURRIS CPU heatsink at Computex 2025
One of the most exciting products from the TRYX Computex boost is its new TURRIS CPU cooler. This is the company’s first air-based CPU cooling solution, and it looks awesome.
The TURRIS is a dual-tower CPU cooler with two fans and six heatpipes. Because of this, the TURRIS immediately falls into the high-performance CPU heatsink category. However, it remains to be seen how well this cooler performs. As of now, we can only comment on its aesthetics.
One of the main draws of the TRYX TURRIS is its 5-inch LCD stats display. This display can be configured using TRYX’s KANALI software, though at this time we do not know exactly what users will be able to do with this screen. All we can say is that the screen is full colour and can clearly display GIFs or video content.
The TURRIS will be available in black and white. TRYX currently plans to release this new heatsink in 2026, which means that would be users will have to wait a while.
The screen on this CPU cooler is magnetically attached to the heatsink, and this heatsink’s fans are attached to the cooling on rails. This allows the screen to be quickly removed for cleaning, and fo its fans to be quickly removed and replaced if required.
If you want this cooler, you will have to wait. As mentioned before, TRYX plans to release this new CPU cooler in 2026. That means that this heatsink may have its design tweaked ahead of launch.
At Computex, TRYX also showed us their new “STAGE” CPU cooler, and Panorama CPU water block.
You can join the discussion on TRYX’s TURRIS CPU cooler on the OC3D Forums.
