Watercool launches HUGE MO-RA IV liquid cooling radiators for 200mm fans
Watercool delivers insane levels of liquid cooling potential with their massive MO-RA IV series radiators
The German liquid cooling specialists over at Watercool have created something MASSIVE! With their new MO-RA IV series of liquid cooling radiators, the company has delivered solutions that are specifically catered to highly overclocked PCs and workstations. These radiators all support multiple 200mm fans, and are all 75mm thick. At its largest, the MO-RA IV series can support up to nine 200mm fans!
The Watercool MO-RA IV series of radiators is available in three forms, with each model being available in black or white. First, we have the MO-RA IV 200, which supports two 200mm fans. Next we have the MO-RA 400, which supports four 200mm fans. Finally, there is the MO-RA IV 600, which supports 9 200mm fans.
Each of these external liquid cooling radiators features a built-in fan splitter for easy cable management. Each unit also features RGB lighting and upgradable segments to add more features to MO-RA series radiators.
The modular nature of this new liquid cooling radiator allows users to install this radiator solution to the side of their PC case, wall mount it, or locate it virtually anywhere you can run cables and tubing to. In theory, you can build a liquid cooled PC with no visible radiators, fans, or reservoirs.
Watercool’s new MO-RA IV series of liquid cooling radiators is available now from the company’s website.
You can join the discussion on WaterCool’s huge MO-RA IV liquid cooling radiators on the OC3D Forums.
