X2 announces their Empire Aluminium Chassis
X2 has just announced their new Empire Aluminium Chassis, which features support for 360mm radiators and glass side panels.
This case has support for GPUs that are up to 400mm long, has three internal 3.5"/2.5" hard drive bays and features a full-length PSU shroud, giving this chassis plenty of room for even the largest of systems while maintaining a clean aesthetic.
The core of this case will be made out of steel, ensuring a robust construction with the outer section of the case being made out of aluminium for a premium aesthetic. At the rear of the chassis is a 120mm RGB LED fan, which allows the case to be easily matched up with your system's colour scheme.
  X2 announces their Empire Aluminium Chassis  X2 announces their Empire Aluminium Chassis
This case will release on the 20th of September in the EU and is currently available to order from X2 in China. The retail price of this chassis will be €152.95/$164.95.
Key features:
  • - Iconic and oblique front panel design
  • - Total space for 7* 120mm cooling fans
  • - 1* 120mm RGB LED fan included on the rear
  • - 2* USB3.0 & 2* USB2.0 + HD-AC97 audio
  • - Removable filters for dust reduction
  • - Super neat and cool internal look
  • - Bottom ATX PSU with bay
    - cover
    - partition divider for better airflow
  • - Sufficient cable management (25mm)
  • - Watercooling
    - radiator up to 360mm mountable
  • - Accommodates up to 400mm long GPUs
  • - Protected glass window side panels
  • - 2 year manufacturer warranty
You can join the discussion on the X2 Empire chassis on the OC3D Forums
«Prev 1 2 Next»
