XSPC Ion pump/reservoir Combo
XSPC Ion pump/reservior
XSPC is soon to release their Ion pump/reservoir, offering a compact design that is designed for water cooling in limited space.
The Ion’s is designed with a versatile bracket that can easily be mounted to any 120/140mm fan, fan mount, or radiator and can rotate and be used at up to four different positions. This allows the pump to be mounted in the majority of PC cases, without the need for any internal modifications.
On each side of the Ion has a G1/4” inlet port, making it easy to neatly route the tubing in your build. On the top of the Ion is a large M20 fill cap, for easy filling and topping up of the reservoir.
The pump reservoir combo is encased in a extruded CNC cut aluminium shell, which is made to match XSPCs AX series of radiators.
Specification:
  • – Dimensions: 58 x 50 x 154mm (excluding accessories)
  • – Maximum Flow: 420 lph (12V)
  • – Maximum Head Delivery: 2m
  • – Power Connector: 4 Pin Molex
  • – Voltage: 12V (Startup 9V)
  • – Power Consumption: 6W
  • – Noise Level: 35dBA
  • – Coolant Capacity: 84ml
  • – Shell Material: Aluminium
  • – Reservoir Material: Acrylic
  • – Maximum Temperature: 60C
  • – Inlets: 2 x G1/4”
  • – Outlet: 1 x G1/4”
  • – Fill Cap: 1 x M20
XSPC Ion pump/reservior  XSPC Ion pump/reservior  XSPC Ion pump/reservior  XSPC Ion pump/reservior
This pump/res combo unit uses the same pump model as XSPC’s 420 and 750 bay reservoir units and will come at a price that is roughly equivalent to the XSPC 420.
XSPC say that this pump unit is expected to start shipping next month.
You can join the discussion on XSPC’s Ion Pump Reservoir unit on the OC3D Forums.
Â
