Zalman Z11 Neo Mid-Tower Case
Published: 28th October 2014 | Source: Zalman |
Zalman has just announced their latest ATX mid-tower case, the Z11 Neo. Featuring a matte-black colour-scheme with glowing blue lighting, the case features a front air-scoop design that's a throwback to some of the oldest gaming-grade mid-towers, from the likes of Zalman, Antec, and Cooler Master. What's changed is modern touches under the hood, and a brushed faux-metal front. Its lone 5.25-inch drive bay which is hidden by a sliding shutter. there is also a large triangular window bulges out from its side, similar to older Zalman Z11 Designs.
The Z11 Neo features an all-black interior, features two concealed 5.25-inch bays and a single exposed one, six 3.5-inch/2.5-inch drive bays, spread between two cages of three bays each. The top cage is detachable which gives the case room for even the largest of GPUs (as long as 400 mm). Ventilation includes two 120 mm front intakes (a blue 120 mm fan comes pre-installed); two top 120 mm exhausts (one pre-installed), a 120 mm rear exhaust, and a 120 mm bottom intake. The intake vents come with dust filters pre-installed. Measuring 205 x 465 x 515 mm (WxHxD).
Zalman didn't announce pricing or availability yet but the case should be available on store shelves soon.
Join the discussion on the Zalman Z11 Neo on the OC3D Forums
Not usually a fan of flashy gamer cases but the Zalman Z11s have always appealed to me somehow. If this gets the same 50 pricetag the other ones have, it's definitely going to be a good purchase for people on budgets!
With the amount of fans included I would be surprised, although on a budget I would look for a case that included enough fans for it to work well out of the box so it's still a contender.
yes it did one at the back one at the top 2 on the side panels and 1 at the frontQuote
