AMD 7 GHz Zen 6 Clock Speed Target “Confirmed” – Leaker Claims
AMD targets 7 GHz clock speeds with its Zen 6 Ryzen Desktop processors
According to a report from Moore’s Law is Dead, multiple sources within AMD have confirmed that the company is targeting clock speeds of 7 GHz with its Zen 6 Desktop “Olympic Ridge” CPUs. This represents a HUGE increase over today’s Zen 5 Ryzen 9000 series CPUs, which can achieve boost clocks of up to 5.7 GHz.
Currently, the final clock speeds of AMD’s Zen 6 CPUs are not yet known. Simply put, AMD needs to test its Zen 6 silicon and determine how fast it can make its next-generation retail products operate. AMD’s Zen 6 Ryzen CPUs are due to launch next year. Now that Zen 6 silicon is coming out of TSMC’s fabs, AMD can test their silicon and see how it performs. The results of this testing will determine how fast AMD’s Zen 6 CPUs will be.
7 GHz is AMD’s target, but can they achieve it?
Moore’s Law is Dead stated that 7 GHz is “kind of the middle of where they’re trying to achieve.” This means that AMD’s Zen 6 silicon could overperform or underperform. Even at the lower end of AMD’s estimates, clock speeds well above 6 GHz are reportedly expected.
If AMD can boost their CPUs to 7 GHz, their next-gen Ryzen CPUs will have boost clocks that are 22.8% higher than their predecessors. That’s a massive boost in single-threaded performance. Add on other architectural benefits, and AMD’s Zen 6 CPUs could be incredibly fast compared to their Zen 5 counterparts.
Okay. So with that said, let me just summarise exactly what I’ve heard about Zen 6 clocks and release dates. I actually have a lot of information here.
Um, basically what I’m told is that they are, without going into detail, they’re definitely achieving 6.4 GHz or higher and the goal is above 7 GHz.
And I say that because it’s not like when I say 7 GHz, there’s like there’s not like multiple sources talking to me and going, “Oh, hopefully we’ll get between six and seven.” And then I’m click baiting by going for, you know, saying 7 GHz. No, 7 GHz is actually kind of in the middle of where they’re trying to achieve, by the way. Um, so I think, like I said before, you can take it to the bank well above 6 GHz. A lot of people think they’ll achieve seven. If they don’t, though, I think above 6.4 most likely. So again, I’m not 100% saying the exact clocks, but that’s because, you know, they don’t know until they know. Like for example, Zen 4 I believe was targeting 5.5 gigahertz and they hoped maybe 5.9 or something and they ended up achieving 5.7. So they can overperform too. It’s just know that when I say 7 GHz, it’s in the middle of the top goal and what they’re sure they’ll achieve already. It’s it’s not at the top end. And so I that’s why I say it is fair for me to say Zen 6 targets 7 GHz because it’s actually targeting at least that.
– Moore’s Law is Dead on AMD’s Zen 6 Olympic Ridge Desktop CPUs
How can AMD achieve 7 GHz with Zen 6?
Two factors are behind AMD’s rumoured Zen 6 CPU clock speeds. These factors are lithography and design. AMD’s reportedly using TSMC’s N2X node to create some of its high-performance Zen 6 CPUs. Today’s Zen 5 CPUs are being built using TSMC’s N4 node. AMD’s moving from TSMC’s N4 node, skipping their N3 node, and using a performance-optimised version of their N2 node (N2X instead of N2/N2P). Note that this gives AMD’s Zen 6 CPUs one of the largest node jumps in AMD’s history.
AMD uses leapfrogging design teams to create its Zen CPUs. As such, Zen 6 is being built by AMD’s Zen 4 design team. Note that AMD’s Zen 4 CPUs featured much higher clock speeds than their Zen 3 counterparts. That expertise is being applied to Zen 6. Through higher clock speeds, AMD hopes to achieve higher levels of single-threaded and multi-threaded performance. With Zen 6, AMD wants to deliver faster cores, not just more cores.
If this report is true, Zen 6 will be an exciting launch for AMD. Higher clock speeds will allow AMD to achieve higher performance levels in all workloads. That’s good news for gamers, creators, and workstation users.
You can join the discussion on AMD’s Zen 7 desktop CPUs targeting 7 GHz clock speeds on the OC3D Forums.
