AMD reveals their low power Ryzen 3 2200GE and Ryzen 5 2400GE APUs
These new models will be called the Ryzen GE series, with the G standing for it use of a dedicated Vega Graphics chip while the E signifies it low power design. At this time both of these APUs have no price listings or availability information, making it unclear whether or not these parts will ever make it onto retail shelves.Â
These two GE versions of the Ryzen 3 2200G and Ryzen 5 2400G offer lower CPU clock speeds than their standard G counterparts, tuned for lower power consumption levels with the same maximum iGPU clock speeds at stock. It is likely that these iGPUs will downclock more often than their high-end counterparts due to AMD’s low-power design.Â
AMD’s website has listed both the Ryzen 3 2200G and Ryzen 5 2400G with no included stock cooler, making them the only Ryzen 2000 series processors to lack a reference Wraith cooler design. This lack of a stock cooler means that AMD either plans to release these coolers with a lower price tag than existing Raven Ridge APUs or that these APUs are designed exclusively for OEM use.Â
 | Ryzen 3 2200GE |
Ryzen 3 2200G | Â | Ryzen 5Â 2400GE |
Ryzen 5 2400G |
CPU Socket | AM4 | AM4 | Â | AM4 | AM4 |
Manufacturing Process | 14nm | 14nm | Â | 14nm | 14nm |
Cores/Threads | 4/4 | 4/4 | Â | 4/8 | 4/8 |
CCX | 4+0 | 4+0 | Â | 4+0 | 4+0 |
CPU Base Clock | 3.2GHz | 3.5GHz | Â | 3.2GHz | 3.6GHz |
CPU Boost Clock | 3.6GHz | 3.7GHz | Â | 3.8GHz | 3.9GHz |
L2 Cache | 2MB | 2MB | Â | 2MB | 2MB |
L3 Cache | 4MB | 4MB | Â | 4MB | 4MB |
Memory Support (Dual Channel) | 2933MHz | 2933MHz | Â | 2933MHz | 2933MHz |
TDP | 35W | 65W | Â | 35W | 65W |
iGPU | Vega | Vega | Â | Vega | Vega |
iGPU Stream Processors | 512 | 512 | Â | 704- | 704 |
iGPUÂ Clock Speed | Up to 1100MHz | up to 1100MHz | Â | Up to 1250MHz | up to 1250MHz |
PCIe Lanes for Dedicated Graphics | 8x | 8x | Â | 8x | 8x |
Included Heatsink | None | Wraith Stealth |  | None | Wraith Stealth |
Â
You can join the discussion on AMD’s new Raven Ridge 2200GE and 2400GE APUs on the OC3D Forums. Â
