ASUS ROG ZENITH II Extreme Alpha is designed for AMD's 64-core Ryzen Threadripper 3990X
Upgraded power stages for 64-core overclocking
Published: 23rd January 2020 | Source: ASUS ROG |
So what's changed? Not much, to our eye, both motherboards look identical, and as far as specifications are concerned, both motherboards are exceptionally similar. Both boards use 16-phase VRMs, offer five M.2 slots, support Wi-Fi 6 and 10 Gbps ethernet and sport a USB 3.2 Gen2x2 connection. The main differences in the original Zenith II Extreme and the Zenith Extreme II Alpha lie under the hood, with ASUS replacing the original Zenith II's 16 Infineon TDA21472 power stages with Infineon TDA21490 power stages.
These power stage changes and other component shifts should help the Zenith II Alpha to handle more power. Strangely, we cannot find any information on Infineon's TDA21490 power stages on the company's website, suggesting that these power stages are newly released models. ASUS has stated that these new power stages are rated at 90 amps, rather than the 70 amps of Infineon's TDA21472 power stages. That gives the ROG TRX40 Zenith II Extreme Alpha a lot more headroom to work with.
At this time, we do not know ASUS' planned release date or pricing for its upgraded TRX40 ROG Zenith Extreme Alpha motherboard, though we expect it to release before AMD's Ryzen Threadripper 3990X processor.
Our review of ASUS' original ROG Zenith II Extreme TRX40 motherboard s available to read here.
You can join the discussion on ASUS' new TRX40 flagship motherboard, the ROG Zenith II Extreme Alpha on the OC3D Forums.
