BIOSTAR has revealed their first Mini-ITX AM4 motherboard
Today BIOSTAR revealed the world’s first ITX AM4 motherboard, sporting AMD’s flagship X370 chipset and up to 32GB of DDR4 memory.
Right now it is unclear how well this compact motherboard will support AMD’s latest 8-core CPUs with XFR, especially when users try to overclock with this board’s X370 chipset. It is likely that overclocking will be limited on this motherboard due to this board’s 7-phase VRM and 4-pin CPU power solution.
This motherboard will come with an x16 PCIe 3.0 slot and an M.2 slot on the rear of the motherboard with x4 PCIe 3.0 connectivity. Storage wise this motherboard supports 4 SATA connections, which should be adequate for any compact system.
Right now BIOSTAR has not revealed when this motherboard will be released to the public or how it will be priced.
You can join the discussion on BIOSTAR’s M-ITX AM4 motherboard on the OC3D Forums.
Â
