Broadwell-E Specifications Leak – 10-Cores and 20-Threads
Broadwell-E Specifications Leak - 10-Cores and 20-Threads
Specifications for Intel’s Broadwell-E CPUs have just been leaked, revealing that Intel is planning to release a 10-core 20-thread i7 CPU this generation. Better still is the fact that this CPU will be usable on currently available X99 motherboards.
The main changes of this CPU from previous generation Extreme series CPUs is that it’s flagship will have two extra CPU cores, a stronger memory controller and the higher power efficiency that Intel’s Broadwell architecture and their 14nm manufacturing process provides.
Specs Sandy Bridge-E Ivy-Bridge E Haswell-E Broadwell-E
Process node
32nm 22nm 22nm 14nm
Flagship
i7 3960X i7 4960X 5960X i7 6950X
Core/thread count
6/12 6/12 8/16 10/20
Cache
15MB  15MB 20MB 25MB
Chipset
X79 X79 X99 X99
Memory Compatibility
DDR3 1600 DDR3 1866 DDR4 2133 DDR4 2400
Launch date
Q4 2011 Q3 2013 Q3 2014 1H 2016
Right now Broadwell E CPU are rumored to be released in the first half of 2016 and launch at the $1000 price point. The CPU is rumored to come at the same clock speed as the currently available intel i7 5960X, but with the small IPC improvements of Broadwell and the increased core count it should give users a 20% performance gain in highly threaded CPU loads.
Specs i7 6950X i7 6900K i7 6850K  i7 6800K
Core/thread count
10/20 8/16 6/12 6/12
CPU clock
3.00GHz 3.30GHz 3.6GHz 3.40GHz
These CPUs will be available in 6-core, 8-core and 10-core models and will come at a range of clock speeds.
You can join the discussion on Broadwell-E’s specifications on the OC3D Forums.
Â
