EK confirms Threadripper 3rd Gen compatibility for its Velocity Series TR4 Water Blocks
EK's already ready for AMD's 3rd Gen Threadripper processors
Published: 2nd December 2019 | Source: EKWB |
EK's Velocity series Thredripper water block ships with an improved fin structure when compared to EK's older block designs, enabling improved cooling performance and lower levels of in-loop friction. EK's sTR4 Velocity water block is designed to feature 91 micro-fins to cover the entire die area of AMD's Threadripper series processors, making this block ideal for all of today's Threadripper processors, even AMD's planned Ryzen Threadripper 3990X.
D-RGB compatible Velocity water blocks are designed with support with all of today's RGB motherboards, connecting via commonly used 3-pin addressable LED connections. The block's standard RGB version, the "EK-Velocity sTR4 - Full Nickel", uses a 4-pin connector and supports most modern RGB enabled motherboards.
EK's new Velocity series TR4 water blocks will be produced in Slovenia and are now available for purchase, starting at €99.90 for the non-RGB versions, €109.90 for the Plexi/Acetal RGB versions and €129.90 for the Full Nickel version.
You can join the discussion on EK's 3rd Generation Velocity series TR4/Threadripper water block on the OC3D Forums.
