Intel Coffee Lake i7 and i5 Hex-core CPU specification leak
Below is a table showcasing the leaked specification of Intel’s upcoming Coffee Lake CPUs, these specifications seem very reasonable for Intel’s 8th generation core CPUs, though the gap between Intel’s i7 8700K and its non-K variant is a lot closer than the last few generations. Â
Â
 | i7 8700K | i7 8700 | i5 8600K | i5 8600 |
Cores | 6 | 6 | 6 | 6 |
Threads | 12 | 12 | 6 | 6 |
L3 Cache | 12MB | 12MB | 9MB | 9MB |
Base Clock | 3.7GHz | 3.2GHz | 3.6GHz | 2.8GHz |
6-core boost | 4.3GHz | 4.3GHz | 4.1GHz | 3.8GHz |
4-core boost | 4.4GHz | 4.3GHz | 4.2GHz | 3.9GHz |
2-core boost | 4.6GHz | 4.5GHz | 4.2GHz | 3.9GHz |
1-core boost | 4.7GHz | 4.6GHz | 4.3GHz | 4.0GHz |
TDP | 95W | 65W | 95W | 65W |
Â
At this time these specifications have not been confirmed by Intel or other sources so, for now, these specifications should not be considered as anything more than a rumour.Â
If these specifications prove to be correct, Coffe Lake will be a powerhouse for Intel’s mainstream CPU socket, offering high clock speeds and a high core count with more affordable motherboards with mainstream sockets.Â
Â
You can join the discussion on Intel’s Coffee Lake series 6-core mainstream CPUs on the OC3D Forums.Â
Â
Â
Â
Â
Â
