Intel Creates Cascade Lake-AP with up to 48 cores with Glued-together design
While this design is groundbreaking for the company, it would be remiss of us to not remind you first of Intel’s Skylake-SP marketing materials, which called AMD’s EPYC series processors “Glued-together” in an effort to drive customers away from the affordable server platform. Â
You can probably guess what Intel has done to achieve such a high core count with Cascade Lake-AP. Yes, they are using two interconnected CPU dies to merge two processors into a single package. You could even go as far to say that Intel has done a “Threadripper” with Cascade Lake-SP, joining two dies together to create an interconnected whole. Can you smell the glue yet?Â
In effect, Cascade Lake-AP is similar to a dual-CPU Cascade Lake-SP setup, which connects two CPU dies together using UPI links, though it is likely that their “on-the-die” interconnect will result in lower CPU-CPU latencies than an equivalent Skylake-SP dual-socket system. Intel hasn’t even used their cutting-edge EMIB technology for inter-die connectivity, a solution that Intel can use to replace silicon interposers on multi-die products.Â
This design is how Intel’s Cascade Lake-AP processors can offer such a high core count and such an insane number of DDR4 memory channels, as the company has, basically, merged two 24-core processors with six memory channels into a single unit. Beyond that, Cascade Lake-AP can scale to a dual-socket setup to offer up to 96 cores on a single system. Strangely, Intel has not mentioned this CPU’s Thread count, suggesting that it may not support Hyperthreading.Â
At this time, Intel has not disclosed the TDP, clock speeds or PCIe configuration of their Cascade Lake-AP series processor, though they have claimed a 3.4X performance boost over AMD’s EPYC 7601 processor in Linpack and a 1.3X increase in Stream Triad performance. On the AI-side, Intel has claimed a 17X boost to Deep Learning Inference performance of their first Intel Xeon Platinum Processors when they first launched. Â
Thanks to Cascade Lake-AP’s large dual -die processor design, and its new 12-channel DDR4 memory subsystem, it is pretty much a given that this new platform will require a new socket to operate, one that is larger than Intel’s already substantial LGA-3467 socket.Â
Intel is expected to release more information about their Cascade Lake-AP processors at the 2018 Annual Supercomputing Conference, though the company has claimed that Cascade Lake-AP will release sometime in the first part 2019, which means that Cascade Lake-SP and AP will likely launch at the same time.Â
You can join the discussion on Intel’s Cascade Lake-AP series of processors on the OC3D Forums.Â
