Intel's X299 Kaby Lake-X overclocking reviewers guide has leaked
Parts of Intel's X299 Kaby Lake-X overclocking reviewers guide has leaked, stating that most good i7 7740K chips will overclock to 5.0GHz at 1.215V and that many chips will be able to exceed 5GHz and reach clock speeds of up to 5.2GHz at higher voltages.
In the guide, it says that the i7 7740K has a "higher overclock ceiling" than the i7 7700K, giving it the potential to offer higher levels of single-threaded performance. It must be noted however that a boost from 5GHz to 5.2GHz is only a 4% improvement, which is likely nowhere near enough performance to consider X299 over Z270.
(Image from Videocardz)
Given the limited memory options (dual channel instead of 4-channel), core options (only 4-cores) and PCIe options (only 16) when using Kaby Lake-X on X299, it looks like it will be hard to recommend these CPUs over existing Z270 offerings.
Kaby Lake-X on X299 has always been considered as a strange inclusion by Intel, offering high levels of single core performance at the expense of quad-channel memory support and the ability to use all of X299's PCIe options, offering a feature set that is almost identical to Z270 on a more expensive motherboard platform.
One thing that remains to be seen is how well the average Skylake-X X299 CPUs will overclock, given their increase core-count and use of Intel's older Skylake CPU core design.
You can join the discussion on Intel's X299 overclocking guide on the OC3D Forums
«Prev 1 Next»
18-06-2017, 10:54:03
AlienALX
Yup and you try finding a "good" one. 5ghz carrot again by Intel.Quote
18-06-2017, 11:56:47
dwatterworth
Always reinforcing that upgrade path on the premium products, why not try to get in a double dip on the chip sales. On the flip side, those quad core chips will probably be a steal on the afterhand market.
I wonder what gives it that further OC range. Power delivery improvements on the platform?Quote
18-06-2017, 13:29:22
Greed4Speed
Looking like a good overclock chip, just hoping x299 boards arent too pricey compared to z270.
fyi i have z77 and looking to upgrade soon.Quote
18-06-2017, 13:51:27
TheF34RChannel
Depending on your usage you may want to wait for Coffee Lake launching August.Quote
18-06-2017, 14:45:42
Greed4Speed
Yes thanks for the reminder, and I am also considering amd, won't be upgrading before August anyway, will be paying a close watch on developments this summerQuote
