Killer overclocking feature revealed for AMD Ryzen 9000 series CPUs
AMD is changing the world of Ryzen overclocking with their new “Curve Shaper” feature
The overclocker 1usmus, has revealed that AMD’s Ryzen 9000 series will be receiving a new overclocking feature in the form of AMD’s “Curve Shaper”. This new feature expands upon AMD’s existing “Curve Optimiser” feature, allowing AMD Ryzen users to further fine-tune their CPUs to maximise system performance.
AMD’s new “Curve Shaper” feature set will be available to Ryzen 9000 series users through their motherboard’s BIOS and through AMD’s Ryzen Master software.
Until now, AMD’s Curve Optimiser technology applied to the entire temperature and load range of Ryzen CPUs. With Curve Shaper, AMD users will be able to create custom Curve Optimiser options across the temperature range. This should allow AMD users to squeeze a little more performance out of their CPUs while maintaining stability. It should also allow users to set their systems up to minimise power draw at idle and maximise CPU performance under load.
Previously, we had to select CO to be stable at both low and high temperatures throughout the entire load range. In most cases the limiting factor was high temperature and low CO. Now everything will change, we will be able to control CO over the whole temperature range.
— 1usmus ðºð¦ (@1usmus) July 2, 2024
Based on this new information, AMD’s Ryzen 9000 series will be an exciting release for overclockers. If you enjoy squeezing every ounce of performance out of your system, AMD’s new Curve Shaper tech will be something to look into.
You can join the discussion on AMD’s new Ryzen 9000 series overclocking options on the OC3D Forums.
