MSI officially launches their MEG Z690 GODLIKE motherboard
MSI has a new flagship Z690 motherboard, and it is ready for PCIe 5.0 M.2 SSDs
Published: 8th February 2022 | Source: MSI |
MSI has launched their MEG Z690 GODLIKE motherboard alongside a "Limited Edition - Plentiful Accessory" version
MSI has officially launch their MEG Z690 GODLIKE motherboard, the company's flagship Alder Lake motherboard. This motherboard supports advanced features like 10Gb ethernet, PCIe 5.0 M.2 SSD support, a direct 20+2 phase VRM with 105A Smart Power Stages and and 8-layer "server grade" PCB.
With six M.2 SSD slots, this motherboard is capable of supporting insane amounts of storage. Only one of these M.2 slots support PCIe 5.0 speeds, though all others support today's newest PCIe 4.0 drives. The MEG Z690 GODLIKE also support Thunderbolt 4, USB 4.0, USB 3.2 Gen 2x2 and more.
One of the unique features of the MEG Z690 GODLIKE features a built-in 3.5-inch IPS LCD M-Vision panel that can be used to monitor motherboard thermals, read debug codes, and fine-tune some of your PC's settings. This LCD can be placed on your motherboard or magnetically connected to your PC case and connected to your motherboard through USB. This allows MSI's M-Vision Dashboard to be used more easily.
MSI plans to ship some of their Limited Edition MEG Z690 GODLIKE motherboards with both a MEG CORELIQUID S360 liquid cooler and a 2X KINGSTON FURY BEAST DDR5 16GB (32GB total) memory kit.
These motherboard kits will be available in limited quantities, and allocation of these motherboard kits will be prioritised to owners of prior MSI GODLIKE motherboards or MSI RTX 3080 or 3090 series graphics cards. Those who are interested in these limited edition motherboards can register their interested in MSI's MEG GODLIKE Z690 Limited Edition Plentiful Accessory motherboard here.
What follows is MSI's press release for their MEG Z690 GODLIKE motherboard.
PR - MSI Formally Launches the MEG Z690 GODLIKE Motherboard
As Intel launched the 12th Gen Core processors and immediately gained lots of attention, MSI also released many motherboards for various usages. However, the best has yet to come until now. Today, the last member of the Z690 platform is here. The one board to rule them all - MEG Z690 GODLIKE. GODLIKE's number one goal for the end-users is evident, designed for the best performance and experience enabled by truly remarkable systems. Whether it's record-breaking overclocking, ultra-customization of ARGB lighting with touch control LCD dashboard, or simply the desire to build the most powerful system imaginable, the MEG Z690 GODLIKE stands unrivaled at the pinnacle of all the Z690 motherboard capabilities.
It is covered in dark, deep, and full aluminium heatsink fashioned with a triangular grid pattern. The illuminating dragon nebula with tempered glass reveals the power with a column of faith and meteor RGB effect. The MEG Z690 GODLIKE symbolizes the endless power of the one universe, ready for every challenge.
Under its powerful appearance, there are multiple patented-pending cooling solutions. The Dual Cross Heat-pipe connects two MOS heatsinks, while the exclusive Wavy Fin Design with 7 W/mK Thermal Pad provides a great surface for heat dissipation. The Magnetic Double-sided M.2 Shield Frozr effectively reduces the high-speed M.2 temperature that helps gamers enjoy its extreme performance while having the lowest operating temperature.
M-Vision Dashboard
It is equipped with the industry's first built-in touchable LCD. The 3.5 inch IPS LCD panel on the motherboard provides the next level of system diagnostics - hardware monitoring, reading debug codes, finding other useful information, and even customizing your display with dedicated MSI software. Moreover, the touchable function enables system operation, fine-tunes complicated PC settings, and even activates the windows function with customization in one touch.
The M-Vision Dashboard connects the motherboard with its easy to disassemble magnetic design. Furthermore, once connected with the GODLIKE rear USB port, the dashboard can operate independently. You can put the dashboard in front of your case, on your desk, or stick to your monitor for easy access. With just one touch, your PC operation received an entire new form.
Extreme Power Solution & Storage Performance
The MEG Z690 GODLIKE features the summit direct power solution, Direct 20+2 Phases with 105 A Smart Power Stage power design, dual 8-pin power connectors with exclusive Core Boost technology, and 8 Layer Server Grade with 2 oz copper PCB. This makes it all the more ready to push the latest processors to their limits!
The incredible onboard 6x M.2 connectors for the maximum storage performance with one Lightning Gen 5 solution allow gamers to get super-fast game speed. Strengthened by Magnetic Double-sided M.2 Shield Frozr, the M.2 SSDs can be cooler and faster.
The Ultimate Performance
GODLIKE features tons of the latest technology to overcome any challenge at hand. Onboard 10G Super LAN, WI-FI 6E Solution with MSI LAN Manager, Dual Thunderbolt 4, USB 4.0, Dual Lightning PCIe 5.0 Slots, Latest DDR5 Memory, Dual Front USB 3.2 Gen 2x2 20G Type-C, Audio Boost 5 HD, and MSI Center software all provide you the "GODLIKE" performance.
There is only a limited quantity of this masterpiece. For those who want to pick up the MEG Z690 GODLIKE, we're offering a prioritized qualification to those who purchased a previous generation of GODLIKE motherboard or an MSI RTX 3080 or 3090 series graphics card before as an appreciation. The limited-edition comes with a MEG CORELIQUID S360 liquid cooler, 2X KINGSTON FURY BEAST DDR5 16G memory, and tons of membership rewards.
For more information, please go to MSI's website.
You can join the discussion on MSI's MEG Z690 GODLIKE motherboard on the OC3D Forums.
