AMD’s Radeon Software 21.3.2 driver preps for Outriders and Evil Genius 2
In DIRT 5, AMD’s Radeon Software 21.3.2 update is designed to deliver improved DirectX ray tracing performance. Sadly, AMD has not stated how much this driver impacts ray tracing performance in their release notes.
Below are AMD’s release notes for their 21.3.2 driver;
Support For
– Outriders
– Evil Genius 2: World Domination
– DIRT 5 Update 4.0
– DirectX Raytracing
Fixed Issues
– Radeon RX 6700 series graphics products may report incorrect core clock values in performance tuning and/or the system graphics hardware information tab.
– Shadows may exhibit corruption in Insurgency: Sandstorm™ on Radeon RX 6000 series graphics products.
– On a limited number of displays, the preferred desktop resolution in Windows® may change when the display is power cycled.
– The start and cancel buttons in the performance tuning stress test may disappear when Radeon Software is resized to be small.
– A black screen may occur on a limited number of displays when Radeon FreeSync is enabled and playing a game set to use borderless fullscreen on Radeon RX 6000 series graphics products.
Known Issues
– Connecting two displays with large differences in resolution/refresh rates may cause flickering on Radeon RX Vega series graphics products.
– Enabling vsync in Rocket League and setting the game to use borderless fullscreen may cause stuttering or ghosting.
– Radeon RX 400 and 500 series graphics products may experience a TDR during extended periods of video playback.
– Brightness flickering may intermittently occur in some games or applications when Radeon™ FreeSync is enabled, and the game is set to use borderless fullscreen.
– Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
Desktop GPUs
Radeon Desktop Product Family Compatibility
Radeon RX 6900XT Radeon RX 6800 Series Radeon RX Navi 5700/5600 Series Radeon VII Radeon RX 5500 Series RX 5300M (Notebook GPU) Radeon RX Vega Series AMD Radeon Pro Duo Radeon RX 580/590 AMD Radeon RX 570 Radeon RX 560 AMD RX 550 Radeon RX 400 Series Graphics AMD Radeon R7 300 Series Graphics AMD Radeon Pro Duo AMD Radeon R7 200 Series Graphics AMD Radeon R9 Fury Series Graphics AMD Radeon R5 300 Series Graphics AMD Radeon R9 Nano Series Graphics AMD Radeon R5 200 Series Graphics AMD Radeon R9 300 Series Graphics AMD Radeon HD 8500 – HD 8900 Series Graphics AMD Radeon R9 200 Series Graphics AMD Radeon HD 7700 – HD 7900 Series Graphics
Supported APUs
AMD Ryzen Mobile Processors with Vega Graphics AMD Athlon Mobile Processors with Vega Graphics AMD A-Series and FX Processors with Radeon Graphics AMD Ryzen pro Mobile Processors with Vega Graphics AMD Athlon Pro Mobile Processors with Vega Graphics AMD A-Series Pro Processors with Radeon Graphics
Download Links
– Windows 10 (64-bit)
You can join the discussion on AMD’s Radeon Software Adrenalin Edition 21.3.2 driver on the OC3D Forums.
