AOC AGON launches its Pro AG276UZD 4K 240Hz QD-OLED monitor
AOC AGON expands its Pro series gaming lineup with a new Quantum Dot OLED monitor
AOC has expanded its QD-OLED lineup with the AGON Pro AG276UZD, a 26.5-inch 4K 240Hz monitor that supports full DisplayPort 2.1 (UHBR20/80 Gbps). This screen features a 4th-gen Samsung QD-OLED panel, has two HDMI 2.1 ports, and supports USB Type-C with 65W power delivery and DP Alt Mode.
With an asking price of £719, this screen is relatively affordable given its 4K 240Hz specifications. The screen is DisplayHDR 400 True Black certified and supports Variable Refresh Rates. This screen is also G-Sync Compatible. The screen boasts 10-bit colour depth and 0.03ms response times, giving this screen strong colour support and motion response characteristics.
With 99.3% DCI-P3 and 100% sRGB colour space support, this monitor is great for both pro and consumer use cases. Within this monitor’s software, users can control the screen’s RGB lighting (on the rear of the screen), enable a low lag mode, and use features like a Crosshair, Shadow control, and enable a framerate counter.
This monitor’s default stand supports tilt, swivel, and 130mm height adjustment. This monitor also supports AGPN’s OLED Care technology and features a 3-year burn-in warranty.
The AGON PRO AG276UZD will be available from June 2025 at an MSRP price of £719.00 in the UK. More information about this monitor is available on AOC’s website.
You can join the discussion on AOC’s AGON Pro AG276UZD 4K 240Hz QD-OLED monitor on the OC3D Forums.
