ASRock launches their RX 6900 XT Formula – Their Fastest Radeon GPU
With a triple-slot heatsink design and a triple-fan cooling configuration, the RX 6900 XT Formula is designed which overclocking in mind, sporting three 8-pin PCIe power connections to feed the GPU under load.
ASRock has designed their RX 6900 XT Formula to be their flagship RDNA 2 product offering, utilising premium components like 90A Power Chokes, Nichicon 12K Black Capacitors, a 2oz Copper PCB and pre-binned RX 6900 XT silicon. These factors are designed to make the RX 6900 XT Formula an excellent card for overclockers and one of the fastest RX 6900 XT graphics cards on the market.
The Radeon RX 6900 XT Formula features a BIOS switch that allows users to switch between P-BIOS (Performance) and Q-BIOS (Quiet) options. In Performance mode, the RX 6900 XT Formula can deliver game clock speeds of 2295MHz and boost clocks of up to 2475MHz. In Quiet mode, the graphics card has game/boost clocks of 2165MHz and 2365MHz, respectively.
Like other RX 6900 XT graphics cards, ASRock’s RX 6900 XT features 16GB of GDDR6 memory, operating at 16 Gbps speeds. The graphics card also offers users a single HDMI 2.1 output and three DisplayPort 1.4 outputs.
The ASRock Radeon RX 6900 XT OC Formula 16GB graphics card offers a 21-phase power design with high-quality components that maximize performance by delivering more power to the GPU.The all-metal cover with a triple-fan cooling system provides excellent heat dissipation. The card’s exclusive Striped Axial Fan enhances airflow and minimizes noise, while the metal backplate protects the PCB from damage. The ARGB LED supports Polychrome SYNC, allowing users to customize lighting effects.
You can join the discussion on ASRock’s RX 6900 XT Formula graphics card on the OC3D Forums.
