ASRock unveils its RX 9070 XT White Taichi GPU with a built-in LCD
ASRock unveils its Radeon RX 9070 XT Taichi White OC graphics card
ASRock has unveiled a new white version of its Radeon RX 9070 XT Taichi, offering gamers an all-white aesthetic and a 2-inch LCD screen. This new GPU will become ASRock’s new flagship model, arriving with more RGB elements and new features.
Performance-wise, this GPU matches the specifications of its non-white Taichi OC counterpart, with a boost clock of 3100 MHz. The GPU also uses a 12V-2×6 power connector for power, unlike most other high-end Radeon RX 9070 XT models. Output-wise, this GPU features three DisplayPort 2.1a ports and one HDMI 2.1b port.
A built-in LCD display and tonnes of RGB
Aside from its white cooling solution and white PCB, ASRock’s biggest change to this GPU is the addition of a 2-inch LCD screen. This screen can display system information, a clock/date, an image or an animation.
Measuring in at 330mm x 140mm x 67mm, this GPU is thicker than ASRock’s Black non-LCD RX 9070 XT Taichi graphics card. The GPU is three PCIe slots wide.
ASRock has not yet unveiled the GPU’s pricing or release date. Regardless, we expect this GPU to become available through retailers soon.
ASRock RX 9070 XT Taichi OC White Specifications
- GPU – AMD Navi 48 XT (RDNA 4)
- Cores – 4096 Stream Processors
- Boost Clock – Up to 3100 MHz
- Memory Speed – 20 Gbps
- Memory – 16GB GDDR6 on a 256-bit memory bus
- Power connector – 1x 12V-2×6
- Features – 2-inch LCD Screen, Dual BIOS, 16-Phase power
You can join the discussion on ASRock’s RX 9070 XT Taichi White GPU on the OC3D Forums.
