ASRock’s custom Taichi and Phantom Gaming RX 7900 XT/XTX designs leak
ASRock's custom Taichi and Phantom Gaming RX 7900 XT/XTX designs leak
ASRock’s custom RDNA 3 GPUs have been pictured
Thanks to Videocardz, we have gotten an early look at ASRock’s RX 7900 XT/XTX Phantom Gaming and Taichi GPU designs, both of which feature triple-fan heatsink designs and RGB illumination.
ASRock’s planned RX 7900 XT/XTX Taichi models appear to be higher-end than their Phantom Gaming counterparts, with the Taichi featuring a triple-slot I/O bracket to support the GPU’s larger heatsink.
Videocardz has reported that ASRock;s RX 7900 XT and RX 7900 XTX Phantom Gaming designs appear to feature slightly different PCB designs, though both graphics cards appear to b nigh-identical without a close inspection of both graphics cards. The XTX model appears to have a wider PCB, though both models feature identical heatsinks.
(ASRock’s RX 7900 XT/XTX Phantom Gaming design)
Both of ASRock’s custom RX 7900 XT/XTX models lack the USB Type-C connectors that are available on AMD’s reference models, with ASRock instead opting to feature three DisplayPort 2.1 ports and a single HDMI 2.1 connection. In contrast, AMD’s reference models feature only two DisplayPort 2.1 connectors.
AMD’s RX 7900 XT and RX 7900 XTX graphics cards will launch on December 13th, and it looks like ASRock will be releasing four custom graphics cards on day-1, with their RX 7900 XT and RX 7900 XTX Phantom Gaming and Taichi models.
You can join the discussion on ASRock’s custom RX 7900 XT/XTX Phantom Gaming and Taichi GPU designs on the OC3D Forums.
