Inno3D unveils single-slot RTX 5080 and RTX 5090 Frostbite Pro graphics cards
Inno3D launches their first single-slot RTX 5080 and RTX 5090 graphics cards using Alphacool water blocks
Inno3D have officially launched their RTX 5090 and RTX 5080 FrostBite Pro graphics cards, single-slot graphics cards that feature Alphacool’s enterprise-grade 1-slot water blocks.
These liquid-cooled GPUs are designed for compact PC enclosures and systems that require multiple add-on cards or GPUs. This makes these GPUs ideal for high-end workstation use and gaming. These graphics cards are smaller than all air-cooled RTX 5080/RTX 5090 graphics cards. Both GPUs feature a chrome-plated copper water block to deliver maximum heat dissipation.
As high-end RTX 50 series GPUs, both of Inno3D’s new Frostbite GPUs support Nvidia DLSS 4, and feature high-speed GDDR7 memory. Both are compatible with Nvidia’s Studio drivers, making them well-suited to high-end workstation applications.
Key features of the INNO3D GeForce RTX 5090 & RTX 5080 Frostbite Pro:
- 1-Slot Design: Optimised for tight enclosures, enabling maximum performance in water-cooled setups
- Precision-crafted copper block: Nearly twice the thermal conductivity of aluminium for exceptional cooling performance
- Redesigned cooling fin geometry: Provides enhanced water flow dynamics, improving GPU stability under heavy loads
- High-end backplate protection: Premium carbon backplate ensures structural integrity while minimising heat buildup
- Slim profile: Allows for multi-GPU setup environments
For more information about Inno3D’s Frostbite Pro RTX 5080 and RTX 5090, please visit their respective product pages.
You can join the discussion on Inno3D’s single-slot RTX 5080 and RTX 5090 graphics cards on the OC3D Forums.
