JSAUX launches their FlipGo Lite 15.6 Portable Dual Monitor
JSAUX follows on from the success of their FlipGo Pro with a 15.6-inch Lite model
Following on from the release of their FlipGo Pro, JSAUX has officially launched a smaller, more affordable variant called the FlipGo Lite, a new entrant in the company’s dual-screen portable screen portfolio.
The FlipGo Lite uses industry standard 15.6-inch IPS displays, offering users two highly portable 1080p screens that can easily be added to desktop or laptop PC setups. Their portability makes these screens ideal for portable workstation use. Beyond that, their magnetic stand support allows them to be moved across multiple setups with ease.
This portable display supports 180-degree folding, allowing users to adjust the FlipGo’s screens to their liking. Users can also use these screens in portrait or landscape mode. Beyond that, this dual 15.6-inch display setup can be used a single, larger screen when necessary.
This multi-screen portable monitor solution is now available with a price tag of $299.99. There are additional accessories that can be purchased such as a magnetic “snap” VESA adapter and a dedicated “snap” stand.
The downside of this new 15.6-inch Lite model is that it features lower resolution and lower quality screens than its more expensive counterparts. Both the 13.5-inch and 16-inch feature many upgraded features. This includes 100% sRGB support, and increased screen brightness. Beyond that, there are versions of this monitor that support “touch screen” capabilities.
Overall, JSAUX’s new portable screen options appear to be a great solution for those who want more screen real estate on the go. The company’s new Lite option makes this multi-screen upgrade option a lot more accessible.
You can join the discussion on JSAUX’s new FlipGo Lite 15.6 Dual Monitor on the OC3D Forums.
