Nvidia launches their RTX 3050 and RTX 3050 Ti Mobile GPUs for laptops
Nvidia’s revolutionised its notebook GPU offerings, upgrading its xx50 series of graphics cards with RTX features, delivering hardware-accelerated ray tracing, and DLSS to mid-range gaming laptops.
Presenting the RTX 3050 and RTX 3050 Ti, two new RTX series graphics cards that are launching as mobile-exclusive products. These GPUs are designed to kick integrated graphics to the curb, offering excellent 1080p gaming performance and increase productivity for video rendering,
When compared to Nvidia’s GTX 1650 series of mobile GPUs, Nvidia offering their mid-range laptop users a tonne of new features. With Ampere, Nvidia’s RTX 3050 series offers gamers AI acceleration with their Tensor cores, Ray Tracing Acceleration with their RT cores and the performance advantages offered by Nvidia’s latest graphics architecture.
Sadly, Nvidia’s RTX 3050 and RTX 3050 Ti will be limited to 4GB of GDDR6 memory, though this will be more than enough memory for many gaming workloads. That said, we would have liked to have seen 8GB models for both the RTX 3050 Ti and RTX 3050.
Pricing-wise, Nvidia’s RTX 3050/3050 Ti-powered laptops are due to release with pricing as low as $799, with models coming from Nvidia launches their RTX 3050 and RTX 3050 Ti Mobile GPUs for laptops.
GPU RTX 3080 Laptop GPU RTX 3070 Laptop GPU RTX 3060 Laptop GPU RTX 3050 Ti Laptop GPU RTX 3050 Laptop GPU
CUDA
Cores
6144 5120 3840 2560 2048
Tensor
Cores
192 160 120 80 64
RT
Cores
48 40 30 20 16
Base/Boost Clock (MHz) 1245/
1710MHz
1290/
1703MHz
1283/
1703MHz
1035/
1695MHz
1057/
1740MHz
Memory 16GB or 8GB GDDR6 8GB GDDR6 6GB GDDR6 4GB GDDR6 4GB GDDR6
Memory Interface Width 256-bit 256-bit 192-bit 128-bit 128-bit
GPU Power (W) 80 to 150 80 to 125 60 to 115 35 to 80 25 to 80
Node 8nm 8nm 8nm 8nm 8nm
PCIe Gen 4 Yes Yes Yes Yes Yes
HDMI 2.1 Yes Yes Yes Yes Yes
With their RTX 3050 Ti, Nvidia’s promising a large performance uplift over the company’s existing GTX 1650 Ti graphics card, promising strong generational improvements in performance and even larger potential performance gains when DLSS is enabled.
In Call of Duty: Warzone, Nvidia’s promising 80 FPS performance with DLSS off and 100 FPS framerates with DLSS On. With their older GTX 1650 Ti graphics card, Nvidia delivers performance numbers of a little over 50 FPS.
Looking at Nvidia’s RTX 3050 and RTX 3050 Ti specifications, Nvidia has launched both of their mobile-focused graphics cards with high TDP ranges, opening the door to various OEM designs with differing performance characteristics. This means that not all RTX 3050 or RTX 3050 Ti laptops will offer the same performance or power draw, though laptop vendors are expected to be transparent and list the power targets of their graphics cards online.
At this time, Nvidia has not revealed desktop variants of their RTX 3050 and RTX 3050 Ti graphics cards.
You can join the discussion on Nvidia’s RTX 3050 and RTX 3050 Ti graphics cards on the OC3D Forums.
