Philips Launches their Evnia 32M2N6800M 4K Mini LED Gaming Monitor
Philips reveals their Evnia 32M2N6800M 4K 144Hz Mini LED Gaming monitor
Philips has revealed their plan to release their new Evnia 32M2N6800M 4K 144Hz Mini LED Gaming monitor this September. The new monitor will launch with a UK MSRP of £739.99, offering users a large 31.5-inch screen size, two HDMI 2.1 inputs, and DisplayPort 1.4 support.
This new monitor is designed with both PC and console gaming in mind, offering support for variable refresh rates, HDR, and fast 1 ms GtG and 0.5 ms MPRT response times.
The Evnia 32M2N6800M is a DisplayHDR 1000 certified display, offering users 1152 dimming zones across its 31.5-inch IPS panel. This enables high contrast ratios and high brightness levels, making this screen ideal for almost any location. Note that this screen supports peak brightness levels of 1250 nits.
Like most high-end Philips displays, this new Evina screen supports Ambiglow. This enhances the viewing experience with RGB ambient lighting that can follow video and audio content.
This screen is well suited to heavy users that would benefit ergonomic screen adjustments. This monitor features a Smart Ergo Base that allows users to adjust the screen’s height and tilt with ease. Additionally, this screen’s flicker-free and low blue light settings can make this screen comfortable to uses for long periods of time.
As mentioned before, the Evnia 32M2N6800M will be available in the UK this September for £739.99.
You can join the discussion on Philips’ Evnia 32M2N6800M 4K Mini LED Gaming Monitor on the OC3D Forums.
