Club 3D makes 3x 4K Multi-Screen setups easy with their latest Multi-Stream Transport (MST) Hub
Need a 3x 4K setup through a single DisplayPort 1.4 connection? This can do it!
Sometimes, people need a lot of screens to be powered from a single PC-side connection. Perhaps your graphics card has only one DisplayPort 1.4 port, but you have dreams of a triple-screen 4K 60Hz workstation setup.
Club 3D has created a product that can enable three 4K 60Hz displays to be powered through a single system-side DisplayPort 1.4 connection, assuming that the user's system supports Display Stream Compression 1.2 (DSC 1.2). If DSC 1.2 isn't supported, the device will support two 60Hz 4K displays.
This device is the "Club 3D Multi Stream Transport (MST) Hub DisplayPort 1.4 Triple Monitor 4K60Hz", which is also called the CSV-7300. The device can support three separate screens in parallel or mirror a desktop over several screens. The CSV_7300 is powered using USB Type-A, whereas the CSV-1550 variant is powered via USB Type-C.
Here's what Club 3D has to say about their latest Multi Stream Transport Hub.
    The Club-3D Multi Stream Transport (MST) Hub DisplayPort 1.4 Triple Monitor is an integrated solution that allows you to enjoy displaying content onto three different monitors / displays simultaneously under MST mode.
The three screens can accommodate displaying different contents in parallel or by simply extending the existing screen, giving a panoramic view of the content which maximizes the user's visual experience. With its multi-display capabilities, this hub can serve as a convenient and hassle-free portable, alternative solution to the conventional docking station. It's the perfect solution for host devices which feature DP1.2 /1.4 graphic cards that supports all DP Alt mode video signal output, for gaming and commercial applications.
You can join the discussion on Club 3D 3x 4K Multi Screen Transport Hub on the OC3D Forums
«Prev 1 Next»
