Cooler Master launch their MasterBox 5 chassis
Published: 7th July 2016 | Source: Cooler Master |
Cooler Master launch their MasterBox 5 series chassis, which offers a straightforward, spacious design which offers support for pretty much any standard system configuration.
This case offers a lot of open space to utilise, supporting up to E-ATX motherboards up to three dual-slot GPUs that are up to 410mm in length and can even fit a 360mm radiator in the front of the chassis if you remove the dual 3.5" drive bays.
From the start of the MasterBox's design process, Cooler Master has designed this case with PC builders in mind, giving end users a lot of flexibility when it comes to mounting SSDs and plenty of room for users to route your system's cables.
This chassis will come in both Black and a two-toned white/black colour scheme, allowing this case to be suited to most offices or gaming areas. A lot of this case's design follows the Cooler Master master Case design aesthetic, giving this case a modern look and feel.
At a price of just $59.99 this case offers a lot of things that budget PC gamers will love and very little in the way of unnecessary features. This case will come with a windowed side panel and should be available in the UK for purchase by the end of the month.
You can join the discussion on Cooler Master's MasterBox 5 chassis on the OC3D Forums.
Cooler Master launch their MasterBox 5 series PC chassis for $59.99.https://t.co/DEMjpueFfQ pic.twitter.com/aC5uBCeOPY
— OC3D (@OC3D) July 7, 2016
