Dell reveals their 40-inch 5K IPS U4021QW Monitor
This screen features a 5K2K resolution and Thunderbolt support
Published: 6th January 2021 | Source: Dell |
With a 5K2K resolution, this screen should be considered the 4K variant of ultrawide resolutions like 2560x1080. It's a 4K screen with an extra bit of width and a 60Hz refresh rate. This screen is designed for creatives who need this much screen real estate, not for gamers.
Dell markets this screen as having a 1,000:1 contrast ratio, 300 cd/m2 brightness and 178/178-degree viewing angles. The screen features 98% DCI-P3 coverage and comes factory calibrated with a dE value of
Dell plans to release this professional-grade monitor for $2,100, offering inputs for Thunderbolt 3, DisplayPort 1.4, HDMI 2.0 and more. The monitor also features a KVM switch with Gigabit LAN, four USB ports and audio connections. For connectivity, the U4021QW features a single USB Type-C port (with 15W power delivery), one Thunderbolt 3 connection (with 90W power delivery and DP Alt Mode), DisplayPort 1.4, 2x HDMI 2.0 and 4x USB ports.
Like many of Dell's other recent UltraSharp monitors, this screen supports Picture in Picture (PiP) and Picture by Picture (PbP) modes so that users can utilise multiple devices on the screen at once.
You can join the discussion on Dell's 40-inch 5K IPS U4021QW monitor on the OC3D Forums.
