EK Releases GIGABYTE GTX 980 Ti WF3 Full-Coverage Water Block
EK Releases GIGABYTE GTX 980 Ti WF3 Full-Coverage Water Block - PR
EK Water Blocks, Ljubljana based premium computer liquid cooling gear manufacturer, is proud to introduce a new Full-Cover water block, designed and engineered specificaly for GIGABYTE Gaming G1 and WindForce 3X series NVIDIA GeForce GTX 980 Ti top-tier graphics cards - the EK-FC980 GTX Ti WF3.
EK Releases GIGABYTE GTX 980 Ti WF3 Full-Coverage Water Block  EK Releases GIGABYTE GTX 980 Ti WF3 Full-Coverage Water Block
EK-FC980 GTX Ti WF3 - with WF3 standing as WindForce 3X abbreviation - is a high-performance Full-Cover water block, designed for GIGABYTE non-reference design GeForce GTX 980 Ti graphics cards. The cooler actively cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas, thus allowing the graphics card and it's VRM to remain stable under high overclocks. Water block aesthetically covers the entire PCB and with the corresponding retention backplate, users get visually stunning GPU in their system.
EK-FC980 GTX Ti WF3 water block features EK unique central inlet split-flow cooling engine design for best possible cooling performance, which also works flawlessly with reversed water flow without adversely affecting the cooling performance. Moreover, such design offers great hydraulic perfromance, allowing this product to be used in liquid cooling systems using weaker water pumps.
The base is made of nickel-plated electrolytic copper while the top is made of quality POM Acetal or acrylic (depending on the variant). Screw-in brass standoffs are pre-installed and allow for safe installation procedure.
You can join the discussion on EK's Gigabyte GTX 980Ti WF3 Water block on the OC3D Forums
«Prev 1 Next»
