EK releases Nvidia GTX 1070 water block
EK has announced the availability of their new GTX 1070 water block, which will be available with Nickel plating and either Acrylic or Acetal tops.
A custom backplate will also be available for this GPU, which is designed to give additional cooling to the GPUs memory and other parts of the circuit board. This backplate will be available as a separate component.
This GPU water block is very similar to EK's existing designs, using EK's innovative split-flow cooling design, which allows this water block to provide great cooling performance while decreasing flow restriction within the block itself. This design allows this water block to be used with even weak low wattage pump designs.
This new waterblock from EK is now available to purchase on EK's own Webshop. Below is a table containing the MSRP of the water block itself and its backplate designs.
You can join the discussion on EK's GTX 1070 water block on the OC3D Forums
«Prev 1 Next»
19-06-2016, 11:15:56
The_Governour
All ways nice of Ek! A 1070 should be nice with a block on it.Quote
19-06-2016, 12:43:29
NeverBackDown
Love it. Just plain black. Can't go wrong with that!Quote
