EK unveils GTX 980 water blocks
PRESS RELEASE
EK Water Blocks, Ljubljana based premium water cooling gear manufacturer, is proud to introduce full-cover water cooling solution for NVIDIA® reference (NVA-1G401) design GeForce® GTX 980 series graphics cards, based on Maxwell GM204 graphics processor.
EK-FC980 GTX directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks.
For the first time ever, the EK-FC980 GTX water block features a central inlet split-flow cooling engine design -  just like with the flagship EK-Supremacy EVO CPU water block - for best possible cooling performance. Such type of heat exchanger also works flawlessly with reversed water flow without adversely affecting the cooling performance. Moreover this radical design offers great hydraulic perfromance allowing this product to be used in liquid cooling systems using weaker water pumps.
"This new cooling engine allows us to increase thermal performance of the cooler by as much as 3°C compared to our previous design", said Niko Tivadar, Project Manager at EK Water Blocks. "Achieved without sacrificing the slim, single-slot form factor design that has been our trademark throughout the years."
Base is made of electrolytic copper (bare- or nickel-plated, depending on the variant) while the top is made of either acrylic- or POM Acetal material. Plexi variants also features two pre-drilled slots for 3mm LED diodes. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure which allows for re-use of the original NVIDIA® backplate.
The EK-FC980 GTX waterblock will be prices between 99.95 and 109.95 Euros and is currently available for Pre-order in at the EK Webshop and other EK partners.
Join the discussion on EK's GTX 980 water block on the OC3D Forums.
«Prev 1 Next»
23-09-2014, 16:15:16
The_Governour
Wow.... this will be so great! I would love to see the possible OC and temps on a water block! A shame that I am on a 780 still..... will have to skip this batch.Quote
23-09-2014, 16:51:59
DamianThorg
Does anyone know if you can keep the GTX980 reference back plate with this installed?Quote
23-09-2014, 17:27:01
JR23
Yeah you definitely can, read it earlier on the EK site.
JRQuote
23-09-2014, 17:31:19
WYP
Yes you can, it's in the article mate!Quote
23-09-2014, 17:54:00
JR23
Did you notice EK had a Nickel backplate listed too that must be shiny as fook
JRQuote
