Fallout 4 mod allows you to use a Jetpack outside of Power Armour
A new Fallout 4 mod allows players to use a Jetpack outside of Power Armour, which is something that i know a lot of you guys have wanted.
The mod adds a new option in the crafting menu of the Chemstation which allows you to build combat armour which comes with a handy Jetpack. Right now there are two versions of the mod available to download, though the only difference between them is the crafting requirements.
  This mod takes the jetpack from power armor and straps it to the back of combat armor. Here are a few of the features…
  • The fire comes out of the correct holes.
  • There is an optional “Lore friendly” version.
  • You can craft it at the chemstation under the “ARMOR” tab
  • You can use a jetpack when not in power armor.
  • The heavy combat armor it’s attached to functions just like normal combat armor.
  • It looks pretty darn cool.
  • Did i mention the fire comes out of the right holes?
Future plans:
  • Make it require appropriate skills and materials to craft. Done.
  • Fix the female version.
  • Add jetpack color options.
  • Fix the animation.
  • Make jetpacks an upgrade option for combat armor,Maybe even all armors.
Changelog:
  • 1.1: Made optional “Lore Friendly” version with more appropriate crafting requirements. Made FOMOD to accommodate new version.
The mod is currently available to download on the Fallout 4 Nexus.
You can join the discussion on Fallout 4’s new Jetpack mod on the OC3D Forums.
Â
