Gigabyte announces their GTX 1080 Xtreme Gaming Water cooled GPU
Gigabyte announces their GTX 1080 Xtreme Gaming Water cooled GPU, which has 16.8M customizable RGB lighting and VR-Link functionality.
This GPU will come with an AIO water cooling unit that is similar in design to AMD's R9 Fury X, offering cooling for all components on the GPU and requires no fan on the GPU to function. This GPU will also come with Gigabyte's Xtreme Care 4-year warranty, though buyers will need to register their product in order to take advantage of this warranty.
In terms of clock speeds this GPU  offers a significant upgrade over the Reference/ Founders Edition GTX 1080, offering base and boost clock speeds of 1759MHz and 1898MHz in the GPUs gaming mode, though users will also have access to higher clock speeds of 1759MHz base and 1936MHz boost when used with Gigabyte's OC Guru II software.
 Nvidia GTX 1080 Founders EditionGigabyte GTX 1080 Xtreme Gaming Water Cooling
GPU Cores25602560
Base clock 1607MHz1784MHz
Boost clock1733MHz1936MHz
Memory TypeGDDR5XGDDR5X
Memory Speed10,000MHz10,000MHz
Power Input8-Pin2x 8-Pin
LED ColourGreenRGB
Power Phase Design5+1 Phase10+1 phase
Price (UK)£619.99
On the rear IO of this GPU gamers will have access to three DisplayPort 1.3/1.4 ports, a single HDMI 2.0b, and a single DVI port. At the other side of the
At the other side of the GPU there are two HDMI connections, which will allow users to link up to two HDMI headers to the front of your case using Gigabyte's VR-Link 5.25" drive bay adapter. Using these two HDMI ports will disable two of the DisplayPort connections at the rear of the GPU.
Right now the pricing of this GPU is unknown, but it is expected to be significantly more expensive than Gigabyte's GTX 1080 Xtreme Gaming, which is currently priced at £659.99.
You can join the discussion on the Gigabyte GTX 1080 Xtreme Gaming on the OC3D Forums
«Prev 1 Next»
17-06-2016, 18:37:42
NeverBackDown
That's one ugly GPU..Quote
17-06-2016, 21:44:03
Dawelio
Hehe seems like everyone is copying Linus with his orange colours...Quote
17-06-2016, 22:40:12
shambles1980
cant stand that guy lol.
Any way!
Why do they all use an aio..
cant they use one of those rads with a pump and res built in and give me barbed connections so i can just hook it up to my loop..Quote
18-06-2016, 05:29:17
Kushiro
Prob cause its a bit less compatible with mounting points. Who knows. Just grab the MSI one or something instead. DIY.Quote
18-06-2016, 09:58:23
Dawelio
Not sure if you mean you can't stand Linus or me ...Quote
