Inno3D's GTX 1070 Founders Edition and Aftermarket versions pictured
Published: 28th May 2016 | Source: Videocardz |
Inno3D's Founders Edition and aftermarket GTX 1070 GPUs have been pictured, showcasing the same cooler designs as their GTX 1080 counterparts.
The GTX 1070 will have only 1920 CUDA cores and 8GB of GDDR5 memory, making it slower than the GTX 1080 on both the GPU core and memory sides, with performance that is said to be slightly faster than the GTX Titan X according to Nvidia.
The GTX 1070 Founders Edition will cost $449, with the aftermarket versions coming later with prices as low as $349. This gives the GTX 1070 some great price to performance, likely making this GPU the new GPU of choice for most enthusiasts.
Below you can see pictures of Inno3D's aftermarket GTX 1070 GPUs, which use Inno3D's new X3 and X4 coolers and will feature factory overclocks.
The difference between the X3 and X4 coolers shown above is that the X4 version will have an extra fan that is dedicated to cooling the GPUs VRMs, which will be useful for heavy overclocking.
Right now the GTX 1070 is a long way from release, with availability starting for the Founders Edition of this GPU on June 10th.
You can join the discussion on Inno3D's GTX 1070 GPUs on the OC3D Forums.
Inno3D's Founders Edition and aftermarket GTX 1070 GPUs have been pictured.https://t.co/T1Ufspbjpc pic.twitter.com/w9JKZEOKdV
— OC3D (@OC3D) May 28, 2016
