LG launch their 42.5-inch 4K 43UD79-B FreeSync Monitor
 Â
Â
The LG 43UD79-B will use a IPS panel which is said to support 10-bit colour, though at this time it is unknown if this is a 10-bit panel or a display at is 8-bit and supports 10-bit colour through display dithering to provide 10-bit colour depth.
With Picture in picture mode, this display can be used to display outputs from multiple systems, allowing this large display to be split into up to 4 separate 1080p outputs. This will allow those working with this monitor to easily split this display for optimal workflow. Â
Â
Â
Â
Right now this display is available to Pre-order for $697 at US retailers, with expected availability from May 9th. At this time it is unknown when this display will reach the UK/European markets, or what price this display will be in Pounds or Euros.Â
Â
You can join the discussion on LG’s 42.5-inch 4K 43UD79-B FreeSync monitor on the OC3D Forums.Â
Â
