LG's UltraGear 48GQ900 48-inch 4K OLED 138Hz monitor is now available to pre-order in the UK
4K, OLED, VRR, 138Hz, and 0.1ms response times - What more can you want?
Published: 21st June 2022 | Source: Overclockers UK |
LG's UltraGear 48GQ900 Large Format OLED Gaming Monitor is now available to Pre-order
At Computex, LG revealed a new large format UltraGear gaming monitor called the 48GQ900, a 48-inch OLED screen that is FreeSync Premium Pro certified, G-Sync compatible, and offers users a maximum refresh rate of 138Hz.
With HDMI 2.1 inputs, and a DisplayPort 1.4 connection, the LG UltraGear 48GQ900 is an ideal gaming display for both PC and console gamers. The screen's OLED panel promises users high levels of colour accuracy, deep blacks, and high fidelity HDR support and 0.1ms response times.
The UltraGear 48GQ900 is now available to pre-order in the UK through Overclockers UK for £1,399.99. Overclockers UK lists this screen as an "Overclockers UK Exclusive", which means that we should not expect to see this monitor on other UK storefronts anytime soon. Stock of this monitor is due to arrive in the UK in August, which means that pre-orderers will need to wait a while for this monitor to become available in the UK.
With the UltraGear 48GQ900, LG has created a TV that offers gamers a hybrid TV/monitor experience. While the screen lacks a TV tuner, the screen's three HDMI 2.1 support allows this monitor to be connected to a wide range of consumer devices, be it an Android TV unit, games consoles like the PlayStation 5, Xbox Series X/S or Switch, or any number of other devices.
Like many other premium LG UltraGear monitors, the UltraGear 48GQ900 supports RGB lighting, which can be adjusted to suit your preferences.
PC gamers can now pre-order LG's UltraGear 48GQ900 gaming monitor through Overclockers UK.
You can join the discussion on LG's UltraGear 48GQ900 48-inch 4K OLED Gaming monitor on the OC3D Forums.
